I’m having an odd issue where RD files that I save from LightBurn do not work on my laser when reading from a USB drive but files saved from RDWorks work fine.
I can see all the files in the UDisk menu, but when I try to do “Copy to mem” with the LightBurn files, I get the error “File Invalid unknown file”
However, when I do the same with a file from RDWorks, it copies to memory fine and runs fine.
I’ve tried multiple USB drives, and made sure I’m using the correct USB port on the machine.
Also, when I send files from LightBurn to the laser via ethernet, it works just fine, and I can even run it again from the laser if I want. It’s just when I use a USB drive with files from LightBurn that I have an issue.
What might be causing this?
