RE: Art Library - Small Icons
Was there a fix for this? I am now having this issue.
screen art lib
Do you regularly run multiple copies of LightBurn at the same time, and are you adding content to the library from both copies? I can’t tell which version of LightBurn you’re running here, but yes, code was added to handle this in 0.9.15, so you can work this way if you on on that version or later.
You’d have to email us that ornament library so I can see if that’s what has happened here.
What are these buttons? From LightBurn or other application?
I dont have them
Both copies are latest, and yes I’m adding and editing from both computer. The library is saved in Dropbox if that matters.
The buttons that are circled are macros I wrote
I’ll send you a copy Oz
There macro buttons on the console screen.
How is it possible to create Macros in LightBurn?
In the console window, if you have a GCode based controller, you can write macros that contain GCode instructions to send to the controller for things like moving the laser, turning on special features, etc. Ruida and other DSP controllers don’t use GCode, and don’t have a console, so you can’t send them macros.
I found the corrupted art file and deleted it. Works fine now.
John
