Mon pc ne reconnait pas mon Sculpfun S9, même en changeant le câble et le port USB, j’ai ce message d’erreur :
En attende de connexion…
ets Jun 8 2016 00:22:57
rst:0x10 (RTCWDT_RTC_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
waiting for download
My PC does not recognize my Sculpfun S9, even by changing the cable and the USB port, I get this error message:
Waiting for connection…
Is this the original board that came with the laser? I suspect it was upgraded or swapped at some point.
Do you have any buttons on the controller? If so, make sure none of them are being accidentally pressed. If none are pressed, check if there’s a reset button and try pushing that and then rebooting the laser.
This is a classical boot loop of a 32bit board. You need to flash the firmware again. If this fails, you need a new mainboard.
A guide is here: Firmware Update & Settings - Diode Laser Wiki
