I am almost fully recovered from a stressful main hard drive failure. but one setting in lightburn is not acting correctly. the scanning offset for some reason is not allowing me to enter 4 decimal places (0.0045) and is only displaying 2 decimal places.
can someone please help? I need 4 decimal places.
Hank
(Hank Morgan)
May 1, 2021, 8:58pm
2
I thought it only allowed 2 decimal places in mm mode but 4 in inches mode. Which are you? Looks like mm.
That must be it! where is that setting found? Thank you!!!
edit: found it!!!
does anyone know where on the hard drive does it store the layer settings?
specifically what file to copy from my old hard drive if I can find it
EDIT: found it!
It’s here if anyone ever needs it (only your profile)
C:\Users\pjohn\AppData\Local\LightBurn
it’s the prefs.ini file
sutick
(Steve Utick)
May 3, 2021, 3:05pm
5
You can also get to that folder easier by selecting File/Open Prefs Folder from the LightBurn toolbar.
Sounds good! I needed to know the path for recovering the file on a damaged hard drive that couldn’t run any programs.
system
(system)
Closed
June 2, 2021, 4:34pm
7
