Red light very Dim
My
light is very very dim on the working platform so I can’t do precise engraving
It’s quite possible that it needs to be focused better, or that it is misaligned internally, and being partially blocked. Fixing either of those things requires opening the part that the scanhead is connected to, removing the laser pointer from the beam combiner, and making adjustments. If this is not something you would be comfortable with doing yourself, you’d need to find someone in your area to do this for you. You can likely contact whoever you purchased from and have them walk you through it as well.
Okay
Thanks
