Hello,
Trying to cut a set of ornaments on my Monport Onyx 55w and experienced my first red ring of death. No data in the console at all in LB…no console built into laser so flying blind here?
i tried cutting 8 at once and it just stopped dead right around the belt. I read that the lid switches have…issues, so checked that and the other switch (crumb tray front cover) and found a loose bracket that acts as a stop…but nothin that would cause it.
i was able to lift lid and get the light to green up, then slap button ans it would try…but then stutter to a halt…you can see these weird dot lines where it tried then failed to continue.
i then tried cuttin one at a time by itself, and it stoppes dead, red ring of doom, exact same spot as the 8 in a row.
As this is a new file that is based off a previous ornament I had cut many of, with a slight (fatal?) Modification, I tried running it.
The original file cut flawlessly, passing the “dead zone” and finished without issue.
Is it possible the gcode is becoming corrupt somehow??
Here is a side by side comparison of the artwork. The failing one is slightly smaller, with a hanger hole on top, and one on bottom for a custom nametag.
I also found that upon inspectinf.my settings, LB is mosifying my LPI to be a very ODD number. I set LPI to 450, and it ovverides upon reload to 424.75. Is it possible my fill LPI is causing an issue? Any insights would be great. Gonna try scaling it up a bit to see if the math of slicing the file hit some sort of physical impossibility for stepping?
