Hey all, Need some advice on reducing engraving times on my 3018 CNC Diode laser engraver. Have included 2 pics of the job I am doing. It is only the text to engrave but as you can see from the preview pic
there is a lot of travel time and its saying it will take 9-10 hours to complete. Its only a 2.5 Diode so have to run around 50% speed & burn at 100%. I have checked & tried settings in the optimization settings but time doesn’t change. Is it possible to engrave each word individually instead of the laser just running back & forth across the panel.
berainlb you just cut my engraving time by half, Thank you for that my friend.
Great. Keep in mind that it might not be all a bed of roses as it may change the output quality depending on your setup.
No worries will try it on a smaller job first. Cheers
