It seems each time I try to connect my laser unit I have to go through finding it again. Same laser and computer. Any idea what I might be doing wrong?
What is prompting you to find it again? Does the name of the laser appear in the Laser window pulldown? If so, try right-clicking on Device button to reconnect. Make sure the port has been detected correctly or pick the right choice.
Do you unplug the USB?
Some OS will change the USB port (com port on pc’s) when it’s connected or reconnected.
Good luck
