This way, the cutting with passes has worked so that each pass has cut the whole geometry.
First, I have noticed that in the latest version, you can’t ungroup the dxf imported geometry. I have tried to Brak apart the function. This function has allowed me to delete unneeded lines. I have grouped the lines in to one object, but the issue I get is the now laser is cutting each line separately.
The question is what I must do that I can get the lines in to merged object. Roman.lbrn2 (26.2 KB)
Ungroup will only ungroup shapes that have been grouped. It doesn’t break apart shapes. I’ve tested ungrouping and don’t notice a problem with ungrouping.
This is because grouping is not the same as joining.
