Hello, I have the image below. I created the blue line using a circle offset. What I am trying to figure out is how do I remove the lines that are in the words? I want to leave the long lines on the left and right. Thanks for the help.
The Boolean modifiers can assist you in achieving this. The following is worth review,
Thank you. I will review right now and see what I can find out.
I have also attached my project if that helps.
NewLogo.lbrn2 (151.9 KB)
This is what I am trying to do. I did this is Adobe Illustrator. I could just pull this in to LightBurn but would love to know if it can be done in LightBurn natively.
This design can be achieved using LightBurn. In this case, I’d use the ‘Ellipse’ tool to start, break the circle into 2 parts (top and bottom halves) to use as anchor paths for text as well as create a fill offset for the bottom black semicircles. Using the ‘Cut Shapes’ to cut, then discard the path at the bottom where the word “Fishing” rests.
Perfect!!! Thank you! That worked like a charm and I learned a new thing about LightBurn!!
