I have a design (not my creation) that has some oddities in it that I’ve been working to clean up so it works with some of the Lightburn features like the Slot Resizing. It seems that some of the objects have extra points that are not connected to the shape. Is there any way to clean up these orphan points easily?
I’ve tried the “Fit shapes to lines” option but no luck.
I just hover over the small red square and press the “D” key for deleting the point. Works fine for a small number of points but would be nice to have the ability to show them without having to move the node that is covering it up.
Unfortunately there are a decent number of nodes and unless I move the joined node I can’t delete the orphaned node (they are coincident). 2nd pic above shows the joined node moved from it’s original location. Hovering over and deleting always deletes the joined node and not the orphan.
Certainly, file is attached. Just for clarification, I don’t think this is a LightBurn issue…just would like a way to solve it in LightBurn. It seems to cause issues with the Slot Resizing tool.
I’ve downloaded the file (twice) and nothing is showing upon opening the file either time.
I even opened the file in Notepad but there’s nothing in the “text” portion either.
Notepad++ shows a long string of many [null] characters.
