This page explains how to remove an old computer - however when get to the stage that I select a specific device/computer, the “three dots” icon is nowhere to be seen. Has it moved somewhere else, or otherwise, how can I remove a device via the portal?
My 3 dots are in the activation window/box after clicking the computer. It just has a delete selection.
@ISL Make sure you’re clicking through the specific hostname that’s activated so that you see detailed activation data for that host. The 3 dot menu is only available in that final screen.
The upper portion of the screen should look something like this. You can see the 3 dots option in the upper right.
