Replace or refresh warped images in LightBurn?
Hi everyone,
I’m trying to make my engraving workflow more efficient, but I’m running into issues when replacing images, especially when warping is involved. Here’s how my process works:
I download images that need to be engraved, they always have the exact same dimensions.
In LightBurn, I’ve created a few template files with tool layers (lining) that show where the engraving should appear on my workbed, this makes sure each alignment is correct.
I import or paste the image, both would work for me, then apply three adjustments:
  • I set the width to 109%
  • I use the Warp Selection tool to slightly curve the image for tapered products
  • I rotate the image 90 degrees and place the image where it should be
The issue comes when I try to replace or refresh the image.
For regular, unwarped images, LightBurn’s Edit → Image Options → Replace or Refresh works great. But for warped images, neither method seems to do anything. The new image doesn’t appear, and the old one stays visible no matter what I do.
My question:
Is there any way to refresh or replace a warped images without having to redo the warp and width adjustments manually each time?
I process a lot of different engravings, and having this step automated or streamlined would make a big difference.
Thanks in advance!
In addition to this: I also notice that every image adjustment, like enhancing Gamma, Contrast, Brightness etcetera, is removed whenever an image is warped
