I’ve talked about my 16MP Arducam setup a few times.
Key thing is a varifocal lens improves the setup enormously, you adjust the zoom to cover the whole bed and nothing more so it won’t waste a lot of pixels of resolution on area you aren’t interested in.
You do need a specific varifocal that fits the imager’s dimensions and if the imager has a built-in IR cut filter, the varifocal should not, and vice-versa. Also need a metal adapter ring.
I also 3d printed an adjustable mount (same as a laser mirror) to fine-tune the angle so, again, we minimize the imager resolution being wasted by being outside the area of interest.
This may have been more trouble than needed, an adjuster nut got loose and lost- it would make sense to 3d print a fixed angle mount with an angle parameter built into CAD, see how far the angle needs correcting, and just change the parameter and reprint a second time with the exact angle you need.
