Replacing A10 head
Hi,
I would like to knw if i can replace Atomstack A10 pro 50w head with something more powerful? or is not possible?
if yes, what do i need?
thank you.
People do this quite frequently.
Unless you purchase it as an upgrade from the manufacturer, it will probably not be a bolt on and plug in type of upgrade.
The laser modules have only a control signal or pwm along with power and ground…
If you get a higher power laser, you might have to get a seperate power supply for it…
I got a pair of these $80 machines from Amazon. The original laser is 500mW and the upgrade was a NEJE 40630 module…
It didn’t just bolt on and plug in…
Good luck
