I have installed this digital ammeter in my K40 so i can keep max current below or up to 15mA. you should be able to use it with your 130W since it is rated up to 999mA and you only need up to ~30mA. once you set max with lightburn you do not really need it anymore as you control max power by the App so speed is not really an issue and i bet it will be as good as analog one cause needle is as slow to react. this digital one samples 5 times a sec - more than enough for the job.
Just not to get confused between K40 digital panel which generates analog voltage to PSU’s TTL input and an Ammeter to measure actual electric current going through the tube. K40’s Digital panel reading is in % and there is no correlation whatsoever with the actual current. so whatever panel you chose, you will have to add an Ammeter - digital or analog based on your preferences.
No need.
Just power your laser using a flux capacitor and then measure the change in earth’s magnetic declination to determine your laser tube actual power output.
Easy money, Just borrow the sum from a black market lender then buy the car and drive to the past to collect your winnings. then come back to the present - that is 1min after borrowing the sum to avoid interest and split the remaining “100 billion dollars” with the rest of us so we can all renew our lightburn licenses in advance for the next 20 years to come.
LightBurn should cost a billion dollars because that’s how much it’s worth. But @LightBurn gives the community a Fillet Mignon at a hamburger and fries price.
