How does the parameters(all) in the shape properties affect the quality of the engraving…especially when I’m doing photorealistic engraving
I assume you’re referring to for an image?
Those parameters are mostly the same as what you find in “Adjust image”. You can see their effect within that window.
Power Scale is a power setting that limits power to a percentage of the cut layer power. You’d only ever change this if you had a very specific reason to do so. Best to leave this alone and adjust power exclusively at the cut layer settings.
@berainlb - I deleted my answer because it was nonsense, everything must be marked before properties are displayed and of course this also applies to pictures. Thank you for your patience
