Reset layers to default on new project
Hi there!
Is it possible to hav eall layers reset do default values on the start of a new project?
I would like that too
Until implemented, one solution to this is to create whatever defaults you’d like and save them to a file called “New Project” and then load it instead of creating a “new” project. Put a text object in the file to remind yourself to Save As a different name right away so you don’t accidentally overwrite the New Project file.
that sounds like a good solution, thanks for the suggestion
Do you use the material library? I am saving default values there.
But most of the time I reuse the same layer for the same thing. Black is always engraving. Red is always cutting. Blue is fill.
Add your votes here: https://lightburn.fider.io/posts/785/reset-layer-settings-with-new-file
(click the up arrow above the number of votes)
