Hello, I’m a newbie in “laserworld” and i really f… up… my lightburn settings… i’ve been trying things out and somehow it’s all messed up. my laserhead wants to go in the wrong direction and makes strange movements and sounds because it is trying to go minus the home point… i’ve tried to uninstall and reinstall lightburn but somewhere the settings are aparently saved, even with an uninstall. There’s nothing wromng with my laser… i’ve installed lightburn on my laptop and it works great so it definatly is computer related… is there any possibility to upload a short movie so you can see and hear what i’m talking about? I’m pretty convinced that my attempt to describe the problem might not be so clear …
If you used the Machine settings to change your controllers configuration, you should save a ‘factory’ copy (sometimes called a ‘backup’) before you change things.
If you did this, you might have to find someone with a similar machine to restore it back…
Lightburn saves some things… might try File → Load Prefs Backup sounds like you couldn’t hurt it any worse…
