I use an Atom Stack A10 Pro at work and I think it’s moving too fast and stopping too roughly, I did some changes to speed up about a month ago, one of changes was turn “fast white space scan” on and setting speed to 5000mm/m. I don’t remember if I change something in “machine settings” the oldest backup I have still have the same settings, is there a way to reset these values to the fabric ones?
I suspect that is machine dependent.
Thanks for the answer and sorry for the late reply. So that means I can’t reset it to the machine’s default? Maybe contacting the support?
Issuing this command in Console may reset to factory defaults:
$RST=*
However, two warnings:
- I don’t know if this command is considered safe on Atomstack units. You may not go to the factory defaults for your machine, but rather a generic setting
- It’s possible this command is disabled on your controller
In any case, I suggest you take a backup of your settings before attempting to run this.
