I have reset my work area and put my cnc on telescopic slides . While at it I decided on adding a vacuum table.
This is the first version. I have sheets of silicone and pvc that I can cut templates out of to increase suction when needed. I have a few vacuum pumps so not sure which one I’ll end up using.
Edit 2:
like I said first prototype. I going to use painter tape to do the framing as it is easy for Templates and cheap to replace.
As for the vacuum I have a 20yr old Oreck vacuum I have been using in my home work area. It is almost perfect and since it’s just vacuum and not cleaning I don’t mind the bags then….
I can almost lift the whole table out of the frame with this setup…
I see i forgot to mention that is will have a film of plastic over it between the material and the bed. when I put my piece down i just puncture through the film below my material. that way all the dusc can stay out of the system.
I am wondering if a vacuum pump can process enough air volume to do the job. A CNC mill shop I visited has 2 each 25hp motors and vortex blowers to do the job on his 4’x8’ table.
It’s all about how much time it takes to evacuate. A 4x8 is a lit of suction space you could do by doing zones where it will pull a vacuums in a 2x2 or even 4x2 2 areas. My problem is some of my work pieces have been hard to due with clamping. As long as I keep a cover over the unused areas it concentrates more suction and keeps pulling extra dust in. If you need to hold a full sheet that is easy enough to clamp.
I was just thinking if you used a manifold and a few solenoids and some suction switches you could zone pull where it will evacuate each zone the. Once all are pulled each zones suction switches would open and close each zone to maintain and you do it where when not using the whole bed you just don’t use those zones…
