I have been able to use resize slot width and slot depth successfully but I cannot get the tab height feature to work. What am I missing? thanks.
It works here, but I have to admit that it doesn’t always work out. Why - I have no idea.
Try posting an example here where it doesn’t work for you.
On the attached file I cannot get either tab height or slot depth to work. It’s weird. Sometimes slot depth works and other times it does not.
Test2.lbrn2 (14.5 KB)
I read on some other threads that this feature is still a bit buggy. Thanks for the response.
Thanks for the help RalphU. Is there a way to do them all at once or do you have click on each one?
If you have a program like Draftsight, you can do them all at once. Not in LB
Yeah, I don’t have Draftsight. I spent about 45 clicking points and then I still have to deal with the corners. UGH. I’m thinking it might be quicker to start from scratch in Pybox .
