Resizing Tabs and Slots
The attached file I am trying to resize the tabs and slots from 3mm to 6mm. Using the video for this feature I was able to get all of the perimeter slot/tabs resized. But the slots I can’t get the tool to recognize the slots to resize them. I used the radius and offset tool to correct the corners and loops but I only get a green box with anchor points at each corner. This is the same for the two tabs at the top of the lid. I am sure there is something with the features that I am missing to make the tool not recognize them but I haven’t been able to find it.
Also for the tolerance how does it work, if you have a segment measurement of 3.03 for 3mm material what value should be put in the tolerance box to catch the difference?
My Lightburn Version
LightBurn 1.7.03
Created by LightBurn Software, LLC
Built on: 2024-10-24 @ 13:13:55 UTC
License Validation Date: 2024-09-24
This release is valid to be used by licenses that were purchased or renewed after or within one year before the license validation date above.
Game Box.lbrn2 (239.0 KB)
Thanks,
Donavon
Use the optimize selected shapes function, not the ones you mentioned.
Then use the change to line option there. Worked for me in most cases. (I wrote a small description here: LightBurn Tips and Tricks - Diode Laser Wiki)
Thanks. This resolved the issues.
