RESOLVED / Camera Alignment Problem
Working to get the LB Camera Wizard to Calibrate Camera Alignment process done, when I click the Capture Image to get the Alignment Image the window remains blank … I’ve gone back to the beginning several times with the same failure point.
Any suggestions? Thank you.
What did you do to fix it?
It appears that the Dark Brown Masonite board I was using to perform the Camera Alignment did not have enough contrast between the engraved pattern and the color of the board. Even though it did not appear too dark I was only able to capture the image once I held a small LED light up to illuminate the work space.
Recommend good lighting and a light colored material for the Camera Alignment process.
Thanks for getting back to me.
