We have been undergoing a number of power outages. Of course they happen when I am in the middle of a project. When this occurs my work on that specific project has come to a halt. Is there a way to have my machine start from wher it ended when the power was lost?
pretty sure there isn’t like you can do with light burn, used to have same issue , got solar now so don’t have to worry about power cuts
I have just re run entire projects again after power cut i know its time wasted, even after re home it has cut pretty actually to original cut lines
Not tested but maybe you can ReZero the machine and use Control Mode to select a line/coordinates and start the job.
hmmm thats worth a trial
It is worth a try..thanks!,
