africa
(burn)
1
[V4.00(8M.H35.20230627)]
[VER:1.1h.2023062702:]
[OPT:VMPH,63,256]
Target buffer size found
[MSG:Using machine:MKS DLC32]
[MSG:Mode=AP:SSDI=MKS_DLC42082:IP=192.168.4.1:MAC=4A-27-E2-84-62-A4]
ok
Homing
error:5
Homing cycle is not enabled in your Grbl settings.
Project loaded in 39 milliseconds
Starting stream
Layer C00
[MSG:Restoring spindle]
jkwilborn
(Jack Wilborn)
2
Is there a question here?
I see you’re getting error:5 and the solution to enable it in grbl…
I’m assuming you don’t know how to enable it in grbl?
Edit → Machine settings
Enable Homing cycle, then write it back to the controller.
system
(system)
Closed
3
