I noticed that the START-command always returns an “OK”, even if no laser is attached, or there is nothing to engrave. Is there a way to know if starting the job was successful?
Is there an overview on what the different commands can return?
There is no error checking via UDP communications.
However here’s about the best I’ve seen on the Ruida.
https://stefan.schuermans.info/rdcam/scrambling.html
I understand that you have to query the controller to figure out some of what it’s doing…
Good luck
