On occasion, I have to “stop” a job while it is engraving a logo; consequently, the laser stops at that position, and I no longer have the original X & Y “0” position. Therefore I cannot return to that point. Is there a way to reclaim that datum point following a stop?
If you use absolute coordinates you have a fixed starting point. If you use user origin you should be able to return to your set origin point. If you use current position, you’re out of luck since the laser doesn’t know where it was originally.
