Returning to start position
Is there a setting to change speed at which laser "Returns to Start Position’
Thanks
If you’re using a GRBL controller, it’s the default rapid speed, which is the maximum travel rate of the controller as set in the firmware. You can override that by issuing a G0 Fxxxx comand when you power up to change the G0 feed speed, where xxxx is in mm/minute.
Thank you Oz :v:
