Hi, I’m using Lightburn 1.6.03, I need to change the direction that my Z table moves.
In the menu Edit->Device Settings->Z Control->Reverse Z direction, nothing changes when I enable/disable the option. The Z motor keeps using the same direction.
Am I doing something wrong? Is this a software bug?
Yes, I’m using a MKS SBase v1.3.
I updated LightBurn to v1.6.03, when using Lightburn v1.2.01 I did not notice the problem. I did not change anything on the firmware I’m using.
Either way, isn’t the setting supposed to invert the direction the motor is rotating?
To make it working in the correct direction, I had to change the direction on the firmware config.txt. Now it works in the direction it is supposed to, but the Lightburn setting still does not change the direction.
My Z stepper is connected to stepper pin 2.2
Entering $$ at the lightburn console gives me an error.
I don’t understand what do you mean.
What the right hand-rule has to do with the lightburn Z direction option not producing any effect?
IMHO if the motor was incorrectly connected, the homing and move comands, would not produce any movement. If they are moving as supposed, in my opinion it is correctly wired. If they are moving, it proves that lightburn can send commands to Z stepper correctly. Only the Z direction option does not produce any change…
First what is the correct direction? Defined by the right-hand rule positive movements
Is your Z axis positive (and negative) movements defined by this rule?
Reversing the Z direction in LightBurn tells it that all Z moves use negative values instead of positive - that’s it.
Most lasers use Z=0 to mean the laser is touching the material (or the laser bed), and positive values move the laser further from the material. If yours does not work that way, you enable the Negative Z switch. It does not affect the jogging window - only Z moves emitted by LightBurn when it’s controlling the Z as part of a job.
That makes sense! Thanks a lot for the information.
I think the tooltip for the option should give that information to the user.
The text, as is, in the tooltip, at least to me, it seems redundant. It does not provide any useful information to understand what it does.
You can often type cat /sd/config.txt to display the config to the console, but the best option for editing the config in Smoothieware is to remove the SD card from the machine, mount it on a PC, and edit the contents of the config.txt file from there.
I think only the last sentence is enough.
“It does not affect the jogging window - only Z moves emitted by LightBurn when it’s controlling the Z as part of a job.”
The help window and description does make you think that Z axis direction is reversed, not just + or -. Was wondering why I had to put in neg. Z offset to make it move up.
