Well, that’s not what I expected. I expected the G54 to have been restored. In either case I think the issue is related to Sculpfun not allowing EEPROM changes.
Try this. After homing run:
G92 X0 Y0
Return results please.
G92 X0 Y0
G92 X0 Y0
ok
<Idle|MPos:-392.000,-397.000,0.000|FS:0,0|WCO:-392.000,-397.000,0.000>
ok
Okay, one more then:
$10=0
ok
$10=0
ok
<Idle|WPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,100>
ok
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:-392.000,-397.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
It behaves strangely, with relative coordinates OK, how to give absolute (even if it looks OK) so it goes out of range.
Can you jog to upper right and check position? Also, I suspect if you power cycle you’ll lose these changes. Worth checking $$ and $# after power cycling.
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=0
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=7
$24=100.000
$25=1500.000
$26=250
$27=3.000
$30=1000
$31=0
$32=1
$100=80.000
$101=80.000
$102=250.000
$110=6000.000
$111=6000.000
$112=1000.000
$120=1000.000
$121=1000.000
$122=1000.000
$130=395.000
$131=410.000
$132=200.000
ok
[TLO:0.000]
ok
Suddenly it seems to be working
Do the changes survive a power cycle? If not, you may need to redo some of these every time you turn on the laser.
I’ll try …
Didn’t survive, so the G92 command is important?
Yes, after G92 X0 Y0 working it. GREATE !!!
Thank you very, very, very much!
