First off, I want to say that I love Lightburn. It’s light years ahead of previous software I was using.
I’m running a new GWeike LC6090 machine with a Ruida controller. I’ve dialed in the machine mostly and it’s giving me amazing results.
However, I recently cut a part for a customer that had some tight corners. I noticed some ringing artifacts along certain edges. I assumed I was running too fast. I initially started at 50mm/s at 90% power and then lowered the speed to 30mm/s, which had significant improvements on the ringing. At 50mm/s I would see ringing at both the yellow area and the red areas. Now the yellow is nice and smooth but I still see some poor edges around the red. This is on 2mm acrylic.
Also - a note that my cut settings have the max and min power settings the same (90%). I’ve tried cutting with these values different (max = 90% and min = 20%), but they didn’t show any noticeable difference.
These were cut with a shim template so there wasn’t any back scattering of laser on the part. I have a kerf offset of 0.125mm in the settings as well.
It looks like it’s mostly along one axis. Does the gantry bounce or vibrate some on sudden direction changes?
I’d make sure that belt tension is… appropriate, neither too tight or loose.
You might also go in to machine settings and turn down the acceleration some and see if that helps.
I’ll have to take a look, it’s hard to tell if the gantry is vibrating - but given the artifacts and the improvement with speed reduction, I would assume it is.
I can try reducing accel as well and see. I think by default it’s set to 2000.
