When I frame in lightburn its to fast. I have tried to slow it down inside the controller which fixed when I box on the controller but still did not change when I frame or box in lightburn. I am also needing to slow down the I guess the jerk when the cup rotates to the other side its to fast.
I’m not sure about Trocen controllers but g-code devices use the Speed specified in Move window for framing. Have you tried reducing that value?
Yeah ive tried changing the speed and does not make a change. I believe on Trcoen devices everything has to be changed on the controller itself not in lightburn.
Which speed settings on the controller have you already changed?
I see this in Trocen documentation. This sounds like it’s specific to framing. Perhaps worth a shot. You may want to make a note of what the current value is before changing anything:
3.15.2.3 RunBox’Speed(mm/s)
The speed at which the laser head makes a circle around the outer frame of the
graph when it does not laser. The maximum value cannot exceed the small value of
【Max Speed】of X and Y axis parameters. If the【Max Speed】of the X-axis is 500 and
the【Max Speed】of the Y-axis is 600, the【RunBox’Speed(mm/s)】<=500. Please refer
to the definition of RunBox’Speed(mm/s) 3.2.6
I saw space speed as well which I thought might be right. Sounds similar to a “rapid move” in CNC parlance.
ill try it when this project gets done and see what happens. Thanks
It was space speed. Thanks for the help!
