I don’t use the roller often, doing almost everything with the chuck, but now I cannot get the roller to frame correctly. It seems like the setting used to have one field grayed out, perhaps roller diameter. I found a post saying the the test button moves 20mm so I change my steps/rotation so that the test rotates item 20mm, but then frame my 100mm graphic on a growler the outside only moves a fraction of that, perhaps 30mm. Last time I used this it was probably on v.11. Tried 360 steps, 35000 steps. What am I missing? attached…
The test does not move the roller 20mm - it spins it one full rotation. If you changed the steps until it only moves 20mm, you’ve done it exactly wrong.
Okay, the 65,000 steps per rotation number is what gives me one full rotation of The Growler I’m trying to do with the test button. But then when I tell it to frame my 100 mm item it spins more than a full rotation very quickly.
The Test button gives one full rotation of the rollers. It will only do a full rotation of the object if you’re using a chuck rotary.
