I hope I get clarity in the following situation.
Machine: UV 5W Galvo.
I use a chuck rotary with an object of Ø 23.5mm in it. (circumference = 73,827 mm)
The rotary uses 12800 steps and is enabled. The Test button in the Rotary Setup gives a nice 360 degree turn.
My settings in Lightburn are:
0.02 mm Line interval
0.02 mm Split Size
The logo in Lightburn is 40 mm high.
After lasering, the lasered logo is only 1mm high. How is this possible ?
(When I go to a bigger diameter (other object) than I have no problems at all.)
