Latest update on DSP V8 Ruida controller machine is a 1390 - won’t frame, starts and stops, rotary has lost all function and locks up the controller, rotary won’t shut off (as I can’t deselect the tab) the drivers from couple years ago (fix for similar problem ) didn’t help
All of this is indicative of a failing power supply, so I’d check that first.
What does it do?
Intermittent or ?
How do you know this? Is the keyboard or controller somehow indicating it’s not operating?
Have you checked the Ruida LEDs and it’s console for any errors?
The same for the motor drivers, they have a red light that indicates an error.
its driver issue- I’m using older version 1.3 to get this job out but it still doesn’t frame
its a driver issue- I’m on an older version 1.3- to get this job out- but still have no framing- but at least rotary functions in this version
