Rotary attachment 6445G
Ok guys this is my first post over here due to a problem that came up today . I am using a chinese laser with a 6445g ruida controller and today i tried to install a rotary attachment.
I know that 6445g can run a rotary attachment additional to the other steppers. So i installed the rotary at the U axis on ruida but couldn’t get this set up through the proccess “setup rotary” in lightburn. I am able to move rotate the chuck from my laser’s control panel but there was no way of setting this up.
Finnaly i unplugged my Y axis and plug it there to get it working . But i would like to use it as an additional driver and not this old fashion way. Is there any workaround , or the software doesn’t support it so i have to forget it …!
Thanks in advance.
You will find several interesting posts using the search term “Ruida rotary firmware”.
This: Search results for 'Ruida rotary firmware order:latest' - LightBurn Software Forum
And this: Search results for 'Ruida rotary firmware' - LightBurn Software Forum
