Rotary chuck set up olm3
Good afternoon I was wondering if y’all could help I have an Ortur laser master 3 10 W laser with the rotary chuck set up. I was trying to figure out on the set up it auto populated 96 mm per rotation when I was wondering if anybody knew if that is the correct set up or just the default that comes with the program, I’m also curious of what you keep your lines per inch at a few cups in the past, but it doesn’t seem to be perfect
Did you do the rotation test using the Test button? It should rotate exactly one rotation, stop, and return to the exact starting position.
Maybe a review of some Lightburn documentation will help…
