Need help with my rotary setup. Each roller is 42 mm, I’m using a NEMA 17 motor at 200 steps per revolution. I’m trying to engrave a 40mm wide image on an object of 234mm in circumference.
However, when starting the process, my test outline covers almost a full revolution of the object. What am I doing wrong?
You’re using the Y axis, not the A axis. I’m not sure I ever completed the handling for using the Y or Z axis for rotary - I’d have to go look, but if the GCode output is the same, I probably never finished it.
