Rotary does not turn
First day I tried my rotary it worked (although the y axis was stretched). Since then the rotary does not turn. When I frame a project the laser head moves on the x axis but the rotary does not rotate on the y axis.
I have rebooted everything and reinstalled the rotary hardware, but no response.
**Rotary works fine with WeCreat Makeit software, but there is no rotation in Lightburn software. Connections and wiring are good but I am not getting the right commands from Lightburn(?)
Is the correct axis selected in the Rotary Setup window/
Are you sure you hooked it up properly? To the controller, it is just another stepper motor on the Yaxis.
Yes, I am sure it is properly installed. It works fine with the WeCreat Makeit software.
It is also set up in the rotary window of LightBurn software correctly. It should work with the an axis option, although I tested all of the options and none of them worked.
Not doubting your word. What interests me is that it worked the first day. That establishes that it will work with Lightburn. What we have to figure out what got changed between day 1 and day 2.
Maybe you could create a second Device new. If you have a .lbdev file, then load that. Maybe a fresh start will help.
I am sure it is impossible to remember everything you did after the end of day 1.
I’m on mobile and unable to check.
If you’re using a CustomGCode device change here from A to Y.
