Added a setting to enable / disable the “Rotary Enable” control on the main window
where I find this option, it was first enabled when I enabled the 4 axis.
thank you
thank you
There is a switch in the upper right of the ‘Settings’ page ()
Turn that to the “ON” position (green) then select “OK” to commit. You should now see the option to control ‘Rotary Enable’ from the ‘Laser’ window.
