has this been resolved?
for future reference, i found this:
I just saw this post. its a little older. Could it be there is just a metric/imperial issue somewhere? Perhaps the 60 mm have not been measured precisely (on the curved surface). If there is a conversion issue the value would be 63,5 (25x2,54). Just a thought…
I have attached a rotary device to my K40/Cohesion3D/Smoothiware (LightBurn 0.9.20) and used the Tools->Rotary Setup to setup the rotary. After calibrating steps/degree in my config.txt file, everything is working well and as expected, except, I do not get the button “Enable Rotary” in my Laser Tab - there is no change to its appearance and I have to go to the rotary setup to disable rotary. Is there an extra step I need to take to enable this button in the Laser tab? This seems much more convenient and safer too.
Did you find one?
