Hi everyone hope you all had a great thanksgiving. my question is is there any instructions on how to run the rotary from beginning to finish
Thanks
“The rotary” is pretty open ended. There are multiple types of rotary, and the way you configure your hardware is different depending on the controller type you have and the type of rotary (chuck or roller).
Since you have a Cohesion 3D, I would check on their forum for advice on setting up the rotary axis first. Once the rotary axis configuration is done, using it is relatively straightforward.
