Rotary printing backwards
Why does my 40 watt laser print backwards when I’m using my chuck type rotary? Have i flip a switch someware?
Usually this means you have to rotate the rotary attachement 180º
Would need to check your machine/ wiring to confirm
Before I updated to 1.5.06 ver the rotary chuck and printing worked fine. Now no matter what i try to I do it just prints back words and look as though as it would be correct if you where in the cup.
Any chance you had to redo the profile and have your Origin set to the wtong corner?
It is possible as I’m new to the laser engraving. Want do i need to do to reset my profile?
