Rotary roller Distorted letters
Most rollers are in the 15mm to 25mm range. If the value is correct, the roller will make exactly one rotation and return with the Test button.
This suggests the item on the rollers is slipping. Too much speed or too strong in acceleration. Try lowering your speed, and laser power to about 25% of the current values.
Here are a couple of helper links…
