Rotary roller setup
Hello,
I have just connected rotary roller to my foxalien mauster pro. Ive watched the videos on how to setup in lightburn. Follow the steps. Roller is enabled and the button is there. However no matter what setting i change in the rotary setup it runs exactly the same distance when i turn a cup. The cup is 260mm. I try and move 260mm but it turns twice about 500mm. Ive change rotary diameter. The steps. But nothing affects the travel. Its like it not recognized the rotary on feature. Any help?
On a roller, when the test button is pressed, the roller need to rotate one complete turn and back, not the object.
With a roller rotary, there is no need for a diameter.
You also need to take into account any kind of gearing ratio between the motor and drive wheel.
Make sense?
