I have a grbl controller creality falcon 40w Lazer using a creality pro rotary chuck.
When the job says it 100% complete its not it says its busy. and you have to restart to do a new job.
it also says Lazer is still in use.
You don’t need to restart, just do a right-click on the devices button to reset the connection.
This is usually not a software issue but a connection issue. Try using a different USB cord and check if it works then.
ty i will try
thank you for your help. after some digging it was operator error, GO FIGURE RIGHT! I didn’t input the right diameter of the cup i was engraving. new to this forum again thank you…
