Hi im setting up my Ortur rotary and when i turn off the auto homing buttons and when i turn on my laser the red light blinks and i cant get the laser unit to connect. Any help will be grateful thank you
Don’t know about Ortur, but on my Ruida I have to let it home, then change out the rotary.
Hopefully the @OrturTech can help you out better…
Hey Jack thanks ill try that next
Hi all! Any updates on this issue? I just ran into the same problem.
I am having the same issue
and the laser goes to negitive numbers on the grid and then says its out of its limits i take the rotary back off and then it goes to X -396 Y -396 and then is out of its work limits did the $RST=* and it back to normal but if i plug in the rotary it goes crazy again
i read to not plug in the rotary with the power on the laser so was worried if i let it home then pluged in the rotary with power it could short out or something i thought to update the firmware would fix this issue but unable to do that no download for the updated firmware on the site
please help got cups to do
to add for the ones that need this info
SET UP
windows 10 on a laptop
ortur laser master 2 pro olf 170
ortur rotary YRR
