I’ve been putting together a simple chuck/spindle rotary laser setup. This is using very basic Marlin/RAMPS setup. I have Y axis checked and enable rotary checked. If I try to alter the settings (mm/rotation or part diameter) I see no changes in the saved gcode. It is as if it is not registering the rotary selection at all. This is 0.9.19 on Ubuntu 20. Thoughts?
This appears to be because Marlin requires a completely independent GCode output path, and I don’t think we’ve ever had a user try a rotary with Marlin before. I’ll have to migrate the rotary scaling code over to that code generator.
Let me know if you’d need any testing on my end.
