Ive got a standard k40 with a mini gerbil controller. No idea what i get change to resolve this issue when its fine with Laserweb.
I tried my spare controller same issue. All the cables are secure in the terminal blocks. Chaisis is grounded. I coudl try another power supply but suspect it will do the same thing.
this what happens when i edit and try to load and test the gcode file with ammendments.
Although I do not think this value being incorrect is likely to cause this particular issue, it is definitely a good move to verify that the $30 value matches the S-Value Max in the Device Settings (Edit â Device Settings) window. 1000 is the default, but 1800 is fine provided the values match in both places.
@Rommel you should also try entering $31=0 in the Console window to set the minimum to 0.
